Quinn_Inuit
I have a 4D Mag sitting around that I'm considering modifying with an LED drop-in module. I've read NewBie's review of the Mag drop-in, and it apparently is hardly heat-sinked at all.
That strikes me as both sill and a problem for the lifespan of the LED, at least if used often. Also, the heat reduces light output, and that's not cool at all.
Therefore, I've been trying to think up a way to bleed off that heat, and I think I may have something. As I understand it, the module sits in the center of the tube, isolated from the walls. Now, I know ~nothing about circuits, so I have no idea if that separation is necessary for the circuit to work or if it's just random. So I just assumed it was necessary. :)
Here's my plan:
What do you think? I've never tried this before, but it sounds like it could work. I'm concerned the paste won't stick to the interior of the Mag. Are there any other glues that might? The paste just needs to bridge from the wire to the outside...some other substance can hold the paste in place if need be.
Alternatively, are there other Mag mods that might be better and easier?
Here's my plan:
- Get some cheap, multi-stranded copper wire. I have some lying around from a Radio Shack purchase about 10 years ago. (It's not like it goes bad. :)
- Wrap the strands around the module.
- Chop off the wire so it almost, but not quite, touches the sides. (So you need somewhat less than 0.5" of wire.)
- Then break out some electrically non-conductive thermal paste of the type used on CPUs. (Example.)
- Use that to glue the wire to the module and to bridge the last bit of distance between the wire and the edge.
