Splunk_Au
I'm planning to set up a solar charging device which would store energy in li-ion cells. I'm just wondering if the heat from being under the sun would affect the cells? Would NiMH be better for this?
Most batteries perform best in the 20°C to 25°C range. Try not to let them get hotter than that if you can help it, or their performance will suffer.
if i were to trickle charge them over 3 days (overnight), does it mean "3 lives" are used up
It can also make the battery wear out more quickly.The 1000 "lives" are charge/discharge cycles at whatever the manufacturer feels the normal rate is. Charging or discharging at a lower/slower rate can actually make the battery last longer.
It depends on many things, and it is really impossible to say. When the specifications say a battery will last for 500 cycles that doesn't mean it will work fine for 500 cycles and then stop working at cycle 501. The battery will gradually fade over time, becoming less and less efficient as time and usage mount up. You get to choose when you think it is not working well enough for your purposes any more.so is trickle charging them with solar for 3 days considered as 3 cycles? im still confused.
and also, if i place them in a normal charger for 10mins and decide to switch off the charger and switch it on after a few mins or hours, is that considered 2 cycles?
However, solar trickle charging is not necessarily good for NiMH cells. NiCd cells are better suited to that application as they are more robust and can better tolerate continuous trickle charging.
No!!i was thinking maybe to use it to recharge li-ions such as 18650 or 10180s
No!!
See post #2. You must never charge Li-ion without a proper charge controller between the power supply and the battery.
This is another thread where it would behoove the interested parties to read and get a proper foundation from www.batteryuniversity.com
Hello Ruriimasu,
The GP ReCyko, and other low self discharge cells, are sensitive to heat. They loose their low self discharge properties when they get hot. I don't know if that loss is permanent or temporary.
Tom
