Help a newbie with first MBI.
the_guy_with_no_name
Thank you Guy! Hope you feel better.
Doug
Hi Doug,
My pleasure of course.
Thanks, feeling much better (being able to walk is a major plus) :thumbsup:
Nothing serious though so should be outrunning the solar system again in a couple of days.
A note on the copper and trits...
Copper is the softest material to work with and often times, when I was adjusting trit holes,
I could mostly rotate the drill bit without even needing a drill.
Most of the time a 2mm drill will do the trick but for some trits, I used a 2.1mm.
Not a huge difference in brightness, but just a little more fullness with the 2mm sized trits.
Installation...
Go very slowly and don't use too much force (I've had a few self-installers who've broken trits on the install, including myself).
If the trit won't go in using only as much force as it takes to push a (full) can of coke across a smooth table, its too much force and best to adjust the size of the hole or use a thinner trit.
1.5mm thickness is guaranteed to fit an 2mm thickness should fit in most cases.
The max length can be up to 8mm but typically its 6mm.
Tgwnn
Cataract
Montreal
Good taste, I have a Cu HF with ice-blue trits too. Don't forget to clean up thoroughly and was your hands obsessively if you break one just to be on the safe side.
climberkid
Goldsboro, NC
Ice blue on my Ti HF with the TV on. Taken with my iPad.
-Alex
shilohsharps
Last thing I need to buy for this Cu HF is a Zoomhead.....I don't think copper is available.....have to decide between Ti and Brass.....decisions, decisions.....
shilohsharps
Thanks Guy,
Think I like the looks of the brass/copper combo.....but, that Ti sure would lighten things up a bit (no paronomasia intended).
Cataract
Montreal
Luckily, the HF is made to fight darkness and bring it into the light :D
... wait a second, doesn't that defeat the purpose? :crackup:
joeray
Newbie question, sorry what's a MBI?
is there a acronyms thread?
thanks
invisible_kid
i noticed on the website only 1 option is available for the ti version mbi-hf. are the other options different leds? and what are the main differences?
Got Lumens?
Champlain Valley
There are Two different switches, a two mode and a three mode.
There are two different LED's a standard CW and the warmer NW.
These options do not include the tritium vial options of installed or not.
GL
