HKT
I just modded my LedLenser David 15(1AA) with Minipro (adjustable) with Seoul P4.
However, it doesn't bright as expected.
I got minipro from my friend , it is adjustable with the switch near IC.
Sorry for no picture of Minipro (adjustable) board.
I removed this switch out after talking with my friend.
But I don't sure the correct way to do.
I've tried to solder the board under the switch (3 points of switch pin) togeter , it does not work.
After remove solder from that 3 points and connect ground to Pin2, it works but not bright as expected.
I measure the current to led with new alkaline cell is only ~110 mA.
Does it normal ?
I wonder it might be Min due to the output.
I don't know that the output after remove is Min or Max.
If it is min , how to be max output?
Thanks for all answer.
Does it normal ?
