To answer these questions
1. Yes, it is primarily for spotting deer.
2. 200-300 yards is the furthest I would be able to actually see without a woods or a hill being blocking my way.
3. It would just need to be about the size of a deer. Larger would be fine, but preferably not smaller.
As for all the suggestions, thank you for them all. I am quickly realizing I will soon be buying as many flashlights as I do blades. And that is not good. :faint:
I am constantly looking out. I have some time to make my decision, and all of the things considered, I know I will end up with more then one.
The Game,
Wasn't that a movie with Ice-T as "the game"?
I should have added as a question in my last post, "will the light be strictly for tracking movement patterns unattached to your gun or will you also be mounting it to a gun and using it with a scope while firing?"
In Michigan, we can hunt deer 1/2 hour before sunrise and 1/2 hour after sunet. So having a 1" barrel, gun-mountable light would be useful although I won't be using mine on my gun. Does bear hunting have similar "daily hours of hunting" laws and if so, will you need your light mounted? You'll need to consider that when choosing your light.
Anyway, based on your needs, if you think you'll definately be taking shots within 200 yards due to natural obstructions, which was a strong consideration for me, and you would prefer to utilize a standard, round, relatively focused beam, then the Tiablo A10-G would be my "personal" recomendation. Of course others will offer more choices to consider.
If your target bear would be beyond the 200 yard range, while using a scope, an aspheric will put an actual spot of light right on a bear. The only thing I wouldn't care for, is the spot will be an actual projection of the square emitter and probably be blue in color. But then as long as it gets the job done, then who cares. I believe some aspherics are more pronounced projections than others.
So if you think aspheric-lens lights would best meet your needs, you would have to get that particular advice from those with that experience.
I really hope I helped a fellow hunter. Best of luck and stay safe! :thumbsup:
John
