Hi,
I am looking for an LED version of a light that has a wide angle of throw. Minimal hot spot, mostly spill. For those old enough, I am more or less looking for a more modern (LED) version of one of the old style incandescent lights that used to take those big square lantern batteries with the springs on top (6 volt as I recall, but that doesn't matter). Some even took the lantern batteries with the screw posts on the top. I'm not necessarily looking for a light that big, just using the above as a reference for the type of illumination I'm looking for. Big wide angle reflectors.
I want a light that can illuminate part of my yard or a wide area outdoors. It doesn't have to be a throw monster and light things up three blocks away. The incandescent types normally had a handle because they were designed large and blocky (to accommodate the battery type). I'm sure many know the style of light I'm trying to describe, I just can't recall the specific name at the moment.
Anyway, is there an LED version comparable (probably better) to the throw/spill and area coverage of these ancient incandescents? I don't really need anything 'tactical'. I don't need 12 modes and a UI that rivals the flight manual for an F-22 fighter. I just want a simple light that turns on fast, is reliable, weather tolerant/resistant, tough construction (can handle a short drop), and hopefully accepts the more common form factor batteries (AA, C, D, and/or rechargeables of the type). One that can illuminate a fairly wide and deep area fairly evenly without necessarily being as bright as the sun. I also would prefer that it isn't a rechargeable with a nonreplaceable proprietary internal battery. Regulation is a must, although runtimes aren't all that vital (longer is great, but not essential). Some modes are also good, but not required (high, low, medium, strobe).
Any ideas and/or suggestions would be appreciated!
