Hmm it is the XM tailcap. Does the body come apart in two pieces or is it just one? The head is the classic surefire shock isolated heads. I dont know the name/model number.
This is a weaponlight turned into a handheld. It is cobbled together with pieces. Its worth is probably not that much. As weaponlights with mounts attached to the body are worth anywhere from $150-$300
i would say you might be able to sell this for $100 but that is the highest.
Thanks for the info. alflys2, and Solscud007. I don't know about the body, it's not in my possession, yet. I've been searching, but not much luck, not even knowing where to start. This should help. All opinions welcome.
It's a model 650-XM00.
That is to say a 'modern' Classic WeaponLight without a mount or remote tape pressure switch.
Of course no such model is sold. It is created by removing the STxx remote switch and the mount. It is something missing fundamental components.
You can build it from an L60 Lamp Module, A21 Classic Universal Housing Body, and an XM00 TailCap
