After seeing the price and performance of P60 drop ins, I have the bug to build a legoable light with a P60 LED head. Here's essentially what I'm after:
Battery: 1 x 18650 or *maybe* the possibility of 2 x CR123
Output: I'll be honest here. I want to turn this light on, on high and have your basic surefire owners say "holy s***!". I'd like to keep up with, or outshine the surefire M6 with the normal lamp.
Modes: I'd love a 3 mode light with an actual low low. 10 lumens would be great, 1 lumen would be totally cool too.
Fit and finish: Good, as in, the finish won't peel off or be easily scraped off. I think this means HAIII.
Beam pattern: I think I want more flood than spot. More on this below.
Run time: At least an hour on high.
Size: "Pocketable". Let's say the basic 6P body would be fine, but something slimmer like the profile of the E2E would be really nice if that's possible.
switch: Tailstandable. Forward or reverse clicky. I've never had a reverse clicky and it strikes me that *maybe* it would be superior for mode switching. Maybe?
My frame of reference is the two lights I spend the most time with: Surefire (original) L2, and HDS U60. I've carried the U60 nearly every day since I bought it 5 or 6 years ago. I used to carry the L2, but the U60 is much easier in the pocket.
As far as their beams go, I think I mostly prefer the flood type beam of the L2, but the beam on the U60 is just fine. I just want more total light output than either one can make. If I have the math right, I really need roughly 3x the lumens output to easily see the difference and roughly 4x the lumens output to think it's "twice as bright". I don't want to start a big discussion of it, but to me that means I really want 400+ real lumens to be a nice big difference from my L2 and/or my U60. Seems like roughly 500 to 600 would be really impressive. I'm looking for validation on this point.
What I've found so far: WOW are there a lot of choices. I mean a LOT.
The two that attract me the most are the Solarforce L2P and the Lumens Factory Seraph. As for drop ins, I think I want a mid level drive XM-L (like 1.5 Amps) or *maybe* an XP-G R5 at essentially the same drive. I really need help with this part because I've never seen any of these emitters actually lit up and I don't have a feel for the difference in actual usable light output between them. This is complicated by seeing enormous differences in output listed for the same emitters in different manufacturer's heads. I know some of them must be exaggerating and/or listing emitter lumens as opposed to OTF lumens. Again, I need help with this. Real life experiences with specific heads would be nice to hear/read.
Finally, I'd like to buy all of these parts from a US distributor that can ship reasonably quickly. I've done business with Light Hound and was very happy with the experience. If they had the SolarForce L2P in stock and a Thrunite XML three mode emitter, I think I would have already ordered it from them. 🙂
As if I haven't asked enough questions already, here's a final one: I think I want to buy an dropin that's 3.7 - 4.2 V so it will get full brightness from a single Liion. But there's more flexibility if I buy a 3 - 9 V head instead, so I can use 2 x CR123 if I want to (which I'm not sure I'll ever do). If I go the route of the 3 - 9, how much output will I lose when using a single Li-ion? Will it be visually noticeable?
Thank you for any and all advice!
Brian.
Brian.
