Please Help,
I want to build a light using a single 18650 battery. I'd like to use either the seoul w42180 U bin LED or the Cree P4 LED (it doesn't matter to me), but am really struggling with what I need to put between the LED and the battery.
Here is an example of a flashlight that has a regulator that does the job:
http://www.dealextreme.com/details.dx/sku.1340
I'm guessing that since the 18650 meets the voltage reqs for the above LEDS, that I don't need a voltage regulator, only a current driver....am I correct on that assumption?
Can any of you recomend to me a driver or regulator that I could use that would allow me to run the above LED at about 700mah? Now, to make this even harder on you, can you reccomend a driver that has a dimmer or PWM to control the beam strength? Preferrable a PWM, because of it's battery saving properties.
