Hi
ive got a new shed ariving this week and i want some lights inside so i can use it as a mini workshop
my plan is first to paint the inside of the shed white then cree leds on an aluminium section attached to the roof inside
not sure how many leds yet at least 4 maybe 8
it is going to be powered from a battery that will be recharged via a solar panel
i have 2 optons
a 2w solar panel that outputs 6 - 9v and 250ma conected to a 3300 nimh 7.2v battery pack
3,3 or 4 sets of - 2 series leds direct drive (leds will be running over 1amp at times but will be well heatsinked)
OR
2w solar panel 12v 120ma connected to a sla 12v 12ah
2 sets of - 3 series or 4 series leds
ok heres the questions
for eather setup do i need a charge controller or can i just wire the solar panel to the battery
will overcharging be an issue
which system should i chose - bear in mind i already have both batterys
thanks
Alex
i have 2 optons
OR
thanks
Alex
