Help Needed !!! dimmable 23v @ 2.1A
siaug18
This is my first post here! hope some one can help. ok here goes;
I have a supply of 12v @ 6A
I need to drive a led bank 7 led in series * 20 parallel = 140 led total
each led has a forward of 3.1v @ 150mA
so thats a voltage of 21.7V @ 2.1A (22-23v @ 3A would be perfect)
I would also like the driver to be dimmable with PWM or a anologue voltage.
one big problem is that i dont want the driver to get too hot ....
I think i will need a boost type driver but I am unable to find a driver that can boost my voltage and offer me the current i need.
any help would be a great help...
You will get more help if you post this in the proper forum. Try to get a Mod to move this to the "Flashlight Electronics" forum. And :welcome:
Welcome to CPF, siaug18.
I'll move the thread for you as Saabluster has suggested.
For a basic non-dimmable supply try a note book power supply designed to run from 12V (i.e. car battery) You should be able to find one that supplies 22V at 2.5A
For a dimmable PWM you could use TaskLed's D2Dim http://www.taskled.com/d2flex.html driven by the above supply.
For a full blown solution look at LTC3783 (you could just use their sample design supplied in their Spice simulator with a little tweeking)
http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,C1031,C1115,P15692
matthew
Before you look for a supply I think you need to make sure that what you want to do is feasible.
First of all it does not look like your numbers add up.
7 x 3.1 = 21.7 V so that looks OK.
But 20 x 0.15 = 3 A, not 2.1 A.
If we look at the power, 21.7 x 3 = 65.1 W
Assuming you need a driver to boost the voltage, there is a need to allow for inefficiencies and provide a margin of error. An efficiency of 80% would be a reasonable allowance, so that would bring the power requirement to
65.1 / 0.8 = 81 W
Your power supply is 12 V @ 6 A = 72 W.
So it seems marginal that you could obtain what you need from a driver with that power supply. You may need to run the LEDs at a lower current or use a larger power supply or something.
sorry about the bad math! I had worked it out to be 3A ... thanks any way.
What I think i will do is split the bank and use 2 ltc3783 Circuits and run the pwm from a pic micro...
I will order in all the parts today and build up a development board to test !
I will post my results as soon as I have any !
Thanks again
:0)
