HELP: Replacement driver for CREE XR-E Flashlight???
  • Thread starter Thread starter z_xfollowthepathx
  • Start date Start date
Z
z_xfollowthepathx
Guest
Hi guys,
A while ago I purchased an LED flashlight from Dealextreme.com [link removed] unfortunately it was broken when it arrived. Sending it back would have cost more than the torch itself, so I tried to fix it myself. I've since discovered that the LED is not the problem (when i connect it directly to a power source it works fine), so I need to replace the driver. My question:
Does anyone know where i can find one?
Im using a CREE XR-E R2 LED at the moment (can be replaced if necessary), with two 18650's. The driver needs to have a diameter of 19/20mm. I've looked on dealextreme, but they don't have any suitable drivers there. Anyone know where I can get one?
Cheerz,
James.
