Thanks in advance.
I have an old ARC LED light marked as follows:
ARC LS LED
LSL-P 271
It is pictured below. This light has been used very little, but the lens appears to have fractured. It is still in one piece, but when I pull a fingernail lightly across the surface I can feel some of the cracks. It needs to be replaced.
I have done enough research to see that ARC is no longer around, so I need a source for the lens, instruction on how to remove the electronics/led from the head (looks simple enough...slots in the edges indicate it might screw out) or, if it's complicated, a suggestion regarding someone who might repair the lens for me.
Again, thanks. Tons of good information here.
ARC LS LED
LSL-P 271
