Yes the formating is confusing.
Fig 4 is the 3 LED at 300-350 ma configuration and Fig 5 is the 3 LED at 1.5 amp. Values of R1 and L1 adjusted for current levels.
Fig 7 and 8 on page 11 give the connection information.
You are right about the inductor part number. It would be helpful to understand what the limits are. The 1.5 amp limit of the IC is the likely limiting factor. Review of the Bourns site for the inductor series might be helpful.
imageicon,
To get back to one of your earlier question. I would say the Eval Kit PCB is usable if you stay with 3 LEDs @ 350ma and keep within the voltage input limits.
Two things come to mind. One is that some drivers don't like open circuits and I don't know if this is one of them. The other is the external connections will be to surface mount pads and not thru-hole pads. Thru-hole would be better for wires, you will just have to be careful with pads. Easy to pull the pad off the PCB while still hot from soldering. The heat briefly weakens the copper foil to PCB base material bond. After it cools it's OK. It's still easy with the wire to pull the pad of the PCB, just be careful.
mike
Hi mike, I think you missed my earlyer point. Download the PDF doc again, all the figure numbers DID change.
The originally posted link was to - AN020_ZD850EVB_MANUAL_07 30 07.pdf
(This matches your figure numbers)
The currently posted link points to - AN020_ZD850EVB_MANUAL_08 24 07.pdf
(notice the changed date)
Maybe you need to clear your browser cache and update the page to see the new link?
The 3 LED 350 mA. example that WAS figure 4 is NOW figure 5, and figure 7 and figure 8 on page 11 are NOW figure 9 and figure 10.
None of the above changes anything substantive about your comments, but it could be a little confusing if someone new to the thread doesn't know that there are two versions.
The figures you referenced on page 11 are just poorly drawn board views, so one would have just about as much luck figuring it out for oneself by just checking out the board with a 10x loop (since it only appears to be a simple two layer board and everything is right there up front).
Of course the chip level diagrams are already available in the ZD850 chip documentation, and if I have to guess at component values and trace circuit pads, then what EXACTLY is the 'EVB MANUAL' doing for me?
Answer NOTHING, it's pretty much USELESS.
Dispite the bad docs for the eval board, I agree that it would be wrong to let the documentation issues spook you and prevent you from considering this chip, which could be a very good performer once you get the connections sorted out.
I also agree that it should not be too hard to sort out these connections on your own, with very little danger that you will goof something up and blow the driver.
This is not a boost converter so accidentally breaking a connection to the LED looks like it will also open circuit the inductor removing drive (I would still be careful to have everything hooked up correctly with good solid solder connections first because some outputs don't like to be open circuited, so it just makes sense to be cautious)
As far as looking at the Bourns site goes, that's not very practical, because they list several Bourns inductor series, but we have NO ASSURANCE THAT THEY ACTUALLY USED ANY OF THEM.
Everyone lists big name suppliers like Bourns, TDK etc for inductors in their datasheet recommendations, but inductors tend to be pricey, so if you can't work the kind of huge volume deal that impresses these companies, you usually end up subbing a cheap generic inductor from some no name vendor, and this could have quite easily happened on the eval board itself.
I am sure the factory can supply this info though.
Again, I don't want to sour anybody on the ZD850 eval board, because at only about 10 bucks it could be a great option, and bad documentation is a pretty common problem that all engineers have to deal with every day (no one will remember or care once you get things figured out and it's working).
