Hahaha i finally got mine and i have you all beat I bought this version and the next step up which has the 5 mode switch (which is EVEN WORSE listen to my story) .. I have NO real tools, So i spent hours using a pair of tweezers (semi thick enforced) trying to twist that switch assembly out, i scratched up the aluminum area around the holes ALOT from the tweasers slipping out (they are pointed).. I used an exacto to scrape out whatever i could between the treads down there.. Tried finger nail polish remover to loosen the glue,.. Tried some Break free gun cleaning oily lube stuff.. NO GO, in the end i just had to keep applying massive amounts of pressure on it, go realy mad and 'creak' broke the glue in the threads finally., what did i find? a cheese square switch with a red button and a hole too small for a GITD cap to fit, i had to enlarge the hole and even still that was with an emery board for finger nails cuz i have no tools! it took a while but i got the whole big enough for the GITD Cap to fit.. tightly.. much better with this switch..
funny thing was that the non 5 mode model (the one this thread was about) i was able to get the HEAD and the switch out with just a little force, it was not NEARLY Glued as bad.. and the record, i think they use super glue down in there.. I was pulling out peices of a clear strong glue.. why do they glue it? argh.. made my life a hassle last night.. bu ti got them working the way i want, with a little wear and tear.
