NutSAK
I've been using a DSD charger for about three years that has always reliably terminated at 4.18 - 4.22 volts. I check the voltage of all batteries coming off this charger when the light turns green.
I've recently purchased a button-top black AW18650 2200mAh that is showing different behavior than all the other AW Li-Ions I've been using (16340 and 18650). When I charge this 18650, the charge terminates in error (red/green LED flash) and the battery tests at 4.20 volts. It appears that the overcharge protection of the battery is kicking in before the DSD determines that the charge is complete.
I contacted the battery retailer about this, and they sent a replacement 18650 that does exactly the same thing. I've since charged all the other Li-Ion batteries I own on this charger, protected and unprotected, and the DSD always finishes with a green light and a resulting battery voltage of 4.18-4.22 volts.
What is going on here? Is the protection circuit in these particular 18650s set to a more sensitive (lower) voltage threshold? Am I going to damage these batteries if I keep hitting the overcharge protection at 4.20 volts? Does the charger need to show a complete charge at a lower voltage?
