snowlover91
- Joined
- Nov 25, 2008
- Messages
- 1,670
I just bought one this morning. the built quality is kind of cheap. but not like it will break under abuse. It's not that bright, but it works fine if you are trying to find something at night in your car or something. I tried to disassemble the head but the board seems to be stamped to the housing. you might need to drill the spots to remove and replace the LED. I am not sure if there's a LED driver. however, there's some space between where the board contacts the battery and the level of the LED.
What would you estimate the lumens at, and what type batteries do these use? Thanks for the help, I might try them out or may stick with my Nitecore D10 on the way!
