tolkaze
Pretty sure this is the place to be. I have a quick question about adding an aspheric to a stock light.
The light in question is a T20C2, the aspheric I am going to use has been harvested from a disassembled Canon 17-85mm camera lens (final focus lens before the sensor)
Now, the apeture of the light at the glass is 29.40mm, and the glass (with plastic shroud) is 27.80mm so very little, if any, light can get past the lens. Now, my question is about reflectors etc, with both the OP and smooth reflector, this lens gives a really bad ring pattern. I am guessing most aspherics do not use reflectors?
also, mounting this lens, I can get a very sharp image of the LED (including wires, etc) by holding it just above the end of the head when reversed, or just below where the head ends when the right way around. Should I mount it with the curve out? or in? does it really affect the sharpness of the focus that much?
This is purely for fun, so its not critical I get it right, I will post some images when I get a chance, and also run some tests to see how much the beam diverges at different lengths
Edit: Images
Measurement of harvested Aspheric
Close up of aspheric
Aspheric and T20C2
Beamshot with OP reflector and head assembly still attached
Beamshot with no front end of head, no reflector (hand held, so its a little bit low)
Bit of a clearer shot, it does focus better than this, but it is hard to handhold a DSLR and the aspheric at the same time
On low
How I was holding it for the shots
Edit: Images
Aspheric and T20C2
On low
