How did I miss this?! Pre-order for Zebralight H30-Q5!
RGB_LED
North of 43
Wow, just found this on the Fenix-store... Did we get a notice on the CPF-MP and I just missed it? Oh well, I'll be sending my order in... https://www.fenix-store.com/product_info.php?cPath=89&products_id=455.
Looks like Fenix-store will be shipping starting April 11! :party:
Specs as indicated on the site...
  • Runs off both primary CR123A and rechargeable RCR123
  • Out the front: High - 80 lumens, Medium - 20 lumens, Low - 4 lumens
  • Narrower flood beam, 80-degree flood beam, without a hotspot.
  • Center area lux reading is about 130% over that of the H50 driven at the same current.
  • Runtimes: High - 2.5 hours, Medium - 21 hours, Low - 3.7 days
  • Recessed lens, as a glare shield plus some protection to the lens.
  • Traditional clip with narrower gap between the clip and the light.
  • Lanyard hole on the clip.
  • Shorter than the H50, volume and weight are about the same:
    • Weight with CR123A - 40g, with battery and headband - 62g
    • Dimensions - 21mm (head portion 25mm), height 56mm
  • Push-button switch for single hand operations.
  • Construction: the head portion and the battery tube portion are in one piece, machined from solid Alcoa aluminum rods, for better heat dissipation. The switch is a light-touch kind with a reliability spec at one million cycles.
Digital 3-level Ramping
Press and hold: Cycle through low, med and high, release to set when ON, click to OFF.
When ON, press and hold: Cycle through low, med, and high, release to set.
___________________________
Just found this thread where the announcement was made... http://www.candlepowerforums.com/vb/showthread.php?t=179644. Would have liked to have seen a separate announcement. Oh well.
I am going to order one of these, but am waiting for Fenix to announce their upcoming headlamp is available.
This will be an incredible backup lamp for caving. . . .
I had Fenix-store rush ship mine right to Milky's house since I was attending PF10. It arrived (thankfully, or I'd be driving back there or have to have Milky ship it to me) and I was able to show it to a lot of people and they really liked it. It's pretty awesome! I'll work up a review tomorrow hoepfully.
I wish that the AA flavor had the touch switch instead of the twisty. :thumbsup:
Check out this tread... if I'm not mistaken, the H501 will be AA but H30 form factor ie. click switch...
http://www.candlepowerforums.com/vb/showthread.php?t=179644&page=6: post #168...
We will release them in the order of H30, H501 and H51. The H501 is an AA version of the H30 (click switch, recessed lens, etc.). The H51 will have a traditional reflector instead of a lens.
:popcorn:
