There isn't a tester that will give a reliable state of charge indication for NiMH batteries, so it isn't worth spending money on even a cheap one.so the best bet is still a cheap battery tester with weak fair strong indicators?
As mentioned by Mr Happy, there is a correlation between voltage and remaining capacity. This correlation works for alkaline batteries and li-ion batteries due to a larger and "less gradual" drop in the battery voltage. This than characteristic can be calibrated to the remaining capacity and the commonly available "good/bad testers" are designed to be used with alkalines.so the best bet is still a cheap battery tester with weak fair strong indicators?
It's like driving my Dad's 1963 Chevy BelAir Station Wagon with the broken gas gauge. You:...my batt is 2100mAh how do i know whether they is still 1700 or 600mAh left in it?
alright thanks guys. i think i will just charge up the batts every 2 months
After driving XX miles, you've used ~(XX/MPG) gallons, so you have ~GAL-(XX/MPG) gallons left.
- Know how many gallons, GAL, the gas tank holds
- Know how many miles-to-the-gallon, MPG, the old Chevy gets
- Write down the mileage reading from the odometer each time you buy gas (you FILL the tank!)
