Hello,
I've just tried my very first power LED: a red-orange Lambertian Luxeon I.
I connected it to two NiMH in series, with a variable resistor to control the current. I occasionally watched at the LED to see if its brightness increased when I changed the resistance value. I quickly realized it was too bright to look at, and put on my sunglasses (very good ones which I use for mountaineering) to protect my eyes. Then I kept on playing with the LED, looking at it for a few seconds at a time occasionally. Since I drove it at 70 mA maximum, its brightness was much less than the nominal brightness at 350 mA.
But when I removed my sunglasses and looked at a white wall, I saw a very distinct and intense blue spot in the middle of my field of view. I was first scared as I feared I had damaged my eyesight. Strangely after looking at the white wall for few seconds the blue spot fainted and became less visible, but if I closed my eyes for a few seconds, as soon as I opened them back the blue spot was here, very intense.
Fortunately after 10 minutes or so it started being less bright, and one hour later it is completely gone. Of course I feel quite relieved, but after this clear warning I will be more careful.
What do you guys wear to protect your eyes when experimenting LEDs?
Would the special "sun eclipse" goggles be OK to look directly at a LED?
Or should I put my LED in a vertical paper cylinder so that it lights the ceiling only, and I can not see it directly?
