Well, i was asking myself this...
I had that old P7 that got a bit damaged in that other thread.
And right now i was trying to destructively test one.
Too bad it failed. It was still running at 10A @ 4.7V. (my PSU doesnt go higher)
The weak point where thermal issues: The P7 was just put on a heatsink with some thermal epoxy, without enough pressure to ensure a thin epoxy film. After reaching 8A, it started to get bluer and bluer. I let it 15 seconds at 10A and then turned it down again, which promptly revered the blue taint when going below 8A again.
Took a look under very low power, and the die is the same as before, no broken bond wires, no additional black spots besides the one that was already there before.
Ah, and it DID get brighter up to the point at 8A where it started to turn blue. Significantly compared to the rated 2.8A.
Dumb thing was my digicam ran out of memory during the movie i made, so it cuts off at 9A (but the turning blue is still noticable). Will link it as soon as i find my stupid micro usb link cable
Anybody elso pushed the p7 to that level or higher? I would be interested if a reflow soldered p7 without that thermal ballast to the HS could go higher before overheating...
(Or is it simply the phosphor getting too hot because of the stokes losses in there. After my calculations, that should have been at least 3-4W at that high power, and the phosphor has a bad thermal interface...)
