Joe Talmadge
Perhaps the question to start with is, what will the E2D do, that the E2e won't? The E2D will cut someone more readily, but bad guys don't break down and cry just because they're cut, and it's very doubtful to me that the E2D will cause eventual stoppage due to blood flow. It's blunt force trauma that will stop a bad guy, and getting hit with the metal rim of an E2e will probably hurt nearly as much as getting hit with an E2D. So my guess, and it's just a guess, is that the E2D would cause more ripping/cutting/bleeding injury, but probably not be decisively more effective than an E2e in actually stopping an assault.
I personally believe that a pocket stick -- as the E2D is being used as, in this discussion -- is not all that useful for someone not trained in its use. It will be useful as a fistload, and at illuminating threats that are a few feet away. The thing is, if you haven't done at least some training in (say) hammerfist blows, you probably won't do them under the pressure of a real assault, and they'll be fairly telegraphed.
In summary:
- Use as a light for identifying threats or a temporary distraction (if you're lucky, it will make the bad guy squint or blink) tool, and also as a fistload, make carry of the E2e or E2D worth it for self defense.
- While I think the E2D, when used as a pocket stick, will cause more bleeding damage than the E2e, I'm not quite convinced it's more of a fight-stopper than an E2d used similarly.
- I'm not convinced of the utility of a pocket stick at all in self-defense, unless some training in its use is done. I'm not trying to be defeatist, just suggesting that other equalizers be considered in your self defense strategy instead of, or in addition to, a pocket stick.
Joe
In summary:
Joe
