how much Volt is a fully chargered NiMH
Tjin
hi there,
I just got a new little travel charger and it shuts down when the voltage in the NiMH batteries hit 1.34 Volts. Doesn't look full to me, since my other chargers will charger to a higher voltage. So can anybody tell me how full a NiMH 1.34Volts is?
It's really difficult to tell how full a NiMH cell is from its voltage.
However, most NiMH cells read higher than 1.4 V right after they come off the charger. It sounds as if your charger may not be applying a full charge.
Are the batteries new and good quality?
well the battery where salvaged from a cordless phone. The are like 600Mah, but they have worked very well. They had been laying around unused for a month or two. But the charger went off after like 5 minutes, so that didn't look right.
hi there,
My Kodak overnight charger that came with my Kodak Pre-charged shuts down at 1.34 volts too.
1.34 is low for a full charge on NIMH... I would suggest perhaps the meter you are using may not be accurate. I have a rayovac 1 hour charger a BC-900 and a 15 minute Energizer charger that all do 1.4v or more on a full charge.
Hello Tjin,
Are you sure your cells are NiMh?
When I charge NiCd cells on a charger that cuts off at a peak voltage, they come off the charger in the 1.34 - 1.39 volt range...
Tom
NiMH is typically about 1.47V hot off the charger, in some cases as high as 1.51V or 1.52V. Nicad is generally about a tenth of a volt less than that (1.37V typically, 1.41V in exceptional cases).
I noticed that there is a correlation between voltage and remaining capacity. That is, when a NiMH cell reads 1.19V or so, in my case it will no longer power the devices I have.
If voltage is a bad way to tell, when how do you tell?
Voltage is a bad way to tell, and there is not really a perfect way that you can tell. You need either to keep track of how much the cells have been used since their last charge, or to use a battery tester like the ZTS to get a rough estimate.
However, voltage does give some clues. A fully discharged NiMH cell can be relied on to read 1.2 V. If a cell reads less than 1.2 V after resting it is almost certainly damaged, or at least very old and worn out. If it reads more than 1.2 V it has some charge in it, but it's hard to say how much. Somewhere in the 1.28 V - 1.34 V range is about half full, and from 1.35 V up to 1.45 V is getting on for fully charged. You can be rather certain that above 1.45 V the cell is fully charged.
