How to attach lense
crackerkorean
I found out that I can use the lenses that I ordered and can use them without the lens holder. But the problem that I am having now is.
Making sure the lens is centered and how to attach it to the star the LED is mounted on.
I was thinking clear silicon RTV to handle any heat. Will this work?
there shouldn't be any heat on your LED just the heatsink below it.
dont use super glue...that stuff i'll mess up your lens and LED dome.
i find that silicone or something like it will work.
I got some silicone adhesive so that should work.
So do I just center the LED by eye?
Thanks for the reply
I also noticed with the luxeon lense holder that there is probably a 2mm gap between the lense and the LED. But since I am not using the holder is it ok to put the lense right on the slug of the LED, or should I use something to create that gap?
