petrev
Hi Lux
Just an idea !
Why not get both temps and you can compare them directly in one head using the Vector Twin ! ! ! then choose your favourite and fit 2 (or keep as a mix maybe ? ? ?
Keep Having Fun
Pete
Actually that sounds like a sweet idea, a blend of 4300/5000K I had been contemplating a focused/unfocused scenario in a Vector twin tooHi Lux
Just an idea !
Keep Having Fun
Pete
Hi Lux
Just an idea !
Keep Having Fun
Pete
This light isnt easy to take apart at all, the batt was glued in????????
And how do I take out the black plastic divider piece without cutting the bunch of small wires to the LED lights?
EDIT: Pete did you Mod the HID Kit wiring at all? Cut some of it back? It looks as tho its gonna be a tight fit in there & the wires might be damaged by the heat of the reflector when resting up againts it?
EDIT#2: Can you still use the 12v DC Outlet?
thx
EDIT: Curious with the 50/55w ratings? Mine are advertised as 55w, but is that 50 or 55w? 10w total is a big diff.
thanks.
OK, got both sets of bulbs to try with ballasts today. Will 2 x 4300 or 2 x 5000, or 1 of each be bestr? :naughty:
