How to wire P7 buck converter from KD?
Lumencraft (Matt)
Vendor
Missouri
I purchased the KD P7 buck converter for my P7 M*g mod, now I need to know how to wire it. The drivers I have used before had a + and - lead that attached to the emitter and a plate where the battery wieres solderd to at the bottom. However this is not the case with my buck converter. Here are some pics.
Also should I leave that rubber thing on the bottom when its wired up?
Thanks everyone
Here you go :thumbsup:
You don't really need the rubber thingie if you completely
glue the driver to the inside of the mag tube just above the
switch assembly with some arctic alumina epoxy.
Thanks Sabrewolf, :thumbsup: I would not have guessed the battery pos was that little tower in the middle. Hopefully my next post will be some beamshots.
