fyrstormer
Banned
If idle hands are the devil's workshop, then I must be the devil. :devil: You all may remember me recently posting this:
Well, now it looks like this:
Can you spot the difference? Here, let me clarify:
Yes, that's a brand-new Luxeon K2, 220lm @ 3.7V x 1.5A. Here's what the beam looks like:
The hotspot is as warm as it looks -- warmer, actually. If I'd had any sense I would've taken a beamshot of the Seoul P4 that used to be in there, but I'm sure there are plenty floating around already. Here's a comparison to a Cree R2 and an OSRAM Golden Dragon, in that order:
So...two big differences I notice:
1. The Luxeon is much more focused, resulting in a much more defined hotspot, though the spill is by no means dim -- this IS one of the brightest single-die LEDs on the market, after all.
2. The tint is so much warmer that at first I thought I'd made a mistake when I ordered the LED; having specified neutral white, I thought I got warm white instead. This thing is warmer than absolutely everything else I have, even the prototype "V0 bin" P4 in the McGizmo PD-S I bought a couple of months ago, which Don described as a "warm brass tint." So it's probably not so great if you're still enamored with the dazzling bluish light from older LEDs.
The color difference is so great that I also thought it was dimmer than the P4 at first, but that was in a brightly-lit room. This being a flashlight, after all, what matters is the light quality in the dark, and outside at night it is readily apparent that the Luxeon is brighter and the warm light is much better for seeing in the dark.
Would mod again.
Would mod again.
