EatSleepRunBike
Has anyone thought of putting both 395 nm and 380 nm leds in the same light? That way you don't have to choose one over the other.
InfidelCastro said:Does this have a decent amount of throw. I'm told the Cree unit above has a little bit of throw to it. I would like to drop it into a camo minimag and use it for scorpion hunting. I'm wondering if a lower wavelength unit would work better though. And I know 5mm LED's aren't exactly designed for throw...
postalguy said:That's the 395 nm wavelenght. It may be powerful, but not as useful as 380 nm.
CM said:Can you define "useful" for the rest of us? While lower wavelength may make certain things flouresce more, the Cree's 390nm is sufficient to make scorpions stand out. I also trust the Cree's. Most UV LED's in those 5mm packages don't last too long encased in epoxy. As little as 10 hours of use will noticeably diminish the output of one of these no-name cheapies. The only good ones I know of are in the Inova X5's.
etc said:I have big lights, small lights, all LEDs, but now I want an UV light.
Probably AA form factor. (Something carryable)
etc said:I hope someone makes a reasonably priced 2AA or 3AA UV LED....
Now it looks like my best best is the MiniMag Conversion.
Here's something to think about when considering how useful a UV light of one wavelength or another might be for a given task:CM said:Can you define "useful" for the rest of us? While lower wavelength may make certain things flouresce more, the Cree's 390nm is sufficient to make scorpions stand out.
Northern Lights said:I have these, both black and grey/aluminum finishes. Works great for scorpions but our use is in fraud and identity. Use on immigration credentials, credit cards and new US currency. I know US Border Patrol agents that got these after seeing mine. I keep giving it up and having to buy me a new one.
- snip -
Sub_Umbra said:EDIT: If you decide to go the 'drop-in-module' route, resist the urge to add a UCL as it's been reported a number of times that the AR coatings on UCL's attenuate light in the UV range.
Northern Lights said:Hello? Post 27 above is a $7.00 light. Three AAs
srvctec said:Ummm, looks like it says 3xAAA NOT three AAs.
