@ Ugrey:
I like incans very much, due to the color of the light. Until now, I say: when I want LED, I buy a Fenix. Actually, I already ordered a P1D Q5 as an EDC. Or... is that just because I'm a noob still ? :oops:
@ Raoul: WHAT do you say?? 700+ Lumens?? From a C3????
I will have the P91 lamp assembly with it, this one consumes 2,7 Amps and throws 200 Lumen or something.... WHAT will the current draw of a lamp that's outputting 700+ Lumens be? I'm sure.... an 17500 battery (or two) won't be able to fire this safely (let alone 16340s) because this will draw WAAYY over 2,2 Amps (which is 2C for a 1100mAh cell, and is thus in fact the limit of what is safely possible.... or you should take those new, high-drain, lower-capacity lithium cells)
It sounds spectacular indeed, but I think I'll keep the P91 for a while to see how it performs. Batteries will be drawn empty in rapid pace already :(
Let's assume, that an AW 17500 cell reaches 1000mAh in real life, instead of the 1100mAh stated.
In this case, runtime with a P91 lamp assembly will be
1/2,7 hour = 22 minutes.
You better stop after 15 minutes to preserve the batteries. LESS runtime than this, and it will be a joke, totally worthless.
I am used to the 5 hours a mini-maglite gave you, and 2 ordinary penlites would last very, very long indeed!
A runtime of an hour is, in my opinion, already short. Even two hours is short for me.
I just modded my 3D Mag a little, I put in a Halogen bulb 4V / 0,85A and put in some very good NiMH-batteries of 8Ah. This will give you very usable light for over 9 hours...
My other 3D mag got a 6,5V / 0,7A lamp, to accomodate a battery-stick from a MagCharger. The new 4Ah-NiMH sticks will provide more than 5,5 hours of light then. And... the lamp will live quite long, in fact it is UNDER-driven a little, but despite that, bright enough for in-the-home use.
Conclusion: Maglites are for runtime, Surefire is for BRIGHTNESS :nana:
(and way better portability than a 3D Mag....)
Timmo.
