fyrstormer
Banned
...the emitter.
I have two Arc6s, one with a Luxeon K2 TFFC and the other with a Cree MC-E. On a whim I decided to test their current draw, each set to Level 7 and using a freshly-charged AW IMR16340 battery. On the Arc6 with the MC-E, the current draw was ~2.3 amps, but on the Arc6 with the K2 TFFC, the current draw was ~4.2 amps! I was amazed; I switched the batteries, in case there was some difference between them, but as I expected, the results were the same.
Needless to say, in addition to the MC-E using almost 50% less power, it also produces a hell of a lot more light. Clearly the Arc6 driver is capable of handling a LOT of power, but with "normal" emitters it's also clearly wasting a lot of that power trying to push the specified current through the emitter. Now I know why the Arc6 with the K2 TFFC heats up so much faster.
The moral of this story is: if you have an Arc6 and you wish it wouldn't assassinate batteries quite so fast, upgrade the emitter. Now that I know the K2 TFFC is thoroughly inferior, I plan to replace it with an SST-50; I'll be interested to see what the results are.
