Sorry, I should have said earlier... I live in the UK. We get a very limited selection of stuff here, and it's much, much more expensive.
For example, the Apex Pro is $160 here. That's a tad over-budget. Well, quite a lot over budget
My concern, and the reason I'm being so damn fussy, is that I won't be able to buy new batteries more than once every 5 days or so. Lithium batteries are the longest lasting, I think, so whatever it is should preferably accept those.
About these CR123s... how do they compare with the Lithium AAs?
[edit: been reading around and there are reports of the Apex being almost guaranteed to break if dropped from any distance. Quite off-putting, if the price hadn't already scared me away ]
So, a little context would probably be in order here. I plan to use said headlamp for a long-distance hike in unfamiliar, potentially dangerous terrain. The main danger would be from tripping over a rock and falling down a sharp incline - that sort of thing. So my aim is simply to get something which is capable of lighting up the area in front of me very well - a sufficient area for moving at walking speed.
I think the Princeton Apex is going to be too heavy. 2AA would be fine, but 4 is starting to be overkill I think As it is, I'm going to be carrying around more weight than I have ever carried before in my life. For several months.
This strikes me as a great idea. I'll read the thread, but I'm a bit dubious about doing it myself, as I've never touched a soldering iron before. Saying that, if it really is hard to mess up, I could always borrow the toolsI'd definitely recommend you get a Princeton Tec EOS, not an Apex.
You can modify it with an SSC star emitter easily and cheaply (there's a huge thread here about how to do this mod) and run it on lithium AAAs. One set might just last you your trip. I have modified both an Apex and an EOS, and for this type of trip I'd leave the Apex at home.
There are folks here who would even sell you a pre-modified EOS if you're interested.
Are you comparing the Apex to the EOS or just saying the Apex is a good light in general?Apex Pro. You will be VERY glad you went a little higher than expected. The 4AA one is too heavy, but the Pro (2x123) is PERFECT!
I'm not a battery expert... do you have to mod the Argo HP to use the Li Ion?so the options are:
* HIGH OUTPUT + largest light: --> PT Apex
(level choice and runtime are questionable. I would not recommend it)
* LOW OUTPUT + SMALL light: --> Zebralight
* OVERALL WINNER: Streamlight ARGO HP,
use a single 17650 Li-Ion batt instead of the expensive CR123s.
If wanting more output, change the old Luxeon led with a Seoul P4 (mod needs 30 mins max)
the Streamlight is the best headlamp available :thumbs up:
PS: dont limit Yourself with wanting to get a light in a shop at Your place. These are lightjears behind (and here in Europe: Petzl. Good light, but several points where they are outdated - for us flashaholics)
PPS: dont forget a small but more powerful handheld light (= Fenix)
And don't forget k9dog, that the nicer the headlamp the more likely
your new camping companions of the night before will 'liberate it'
from your pack while you are down at the creek getting water for
breakfast.
