[ QUOTE ]
VidPro said:
[ QUOTE ]
evan9162 said:
A Luxeon I running at 350mA on the star board with no heat sinking in free air will stabilize to 60C board temperature. This puts the junction temperature at 80C. Increasing the current will both increase the stabilized temperature, and the junction temperature (both by increasing the stabilized temp, and increasing the thermal differential between junction an board due to increased power dissipation).
It sounds like you just need more heatsinking period.
The vast majority of power in an LED is converted to heat. Consider that the best lab samples hit 25% efficiency. Only about 10-15% of the power dissipated in a Luxeon gets turned into light. So 3W of power in means 3W of heat to dissipate.
[/ QUOTE ]
well that answers 2 question.
so is a 80* junction temp a bad thing?
would you say that something like these 3W drop-ins (pr2 replacements) run low enough to achieve 80*?
does 3 LUXIIIs in a Mag body, with a 2" heat sink stay at 80* ?
does anybody have lights that are achieveing the 80* when they are encased , and 100% sealed, when they are run for a full hour?
better question, would lots of these lights melt plastic if it was put on the heat syncs they use?
[/ QUOTE ]
80C is okay...lower is obviously better. With the heatsinks I make for Mag mods, I keep my Luxeon V mods get to a MAX of 85C Tj, after 45 minutes of sitting still. My Lux I at 580mA Mag gets to a maximum Tj of 55C. The 1.4A R/O I just built, max Tj of 65C.
Some of the Lux III drop-ins are terribly designed - I'm mostly talking about the Diamond one. Craig (LED Museum) reviewed one, and the temp of the drop-in got to 95C! It was running at 700mA, so the Tj there is just under 130C, or right at the thermal limit...a poor design indeed.
On the other hand, the EverLed has built-in thermal management, that prevents the luxeon from overheating - that's a well designed drop-in with proper thought given to thermal issues.
Keeping a Luxeon III running at 1A with a Tj of 80C or less is quite difficult - you would have to keep the heatsink at around room temperature. I'm sure most if not all tri-Lux III mods end up with a Tj of 100C or more.
I have a plastic body light that I put a luxeon into - but I keep the current to around 250mA, otherwise the heatsink inside just gets too hot.
I'm not sure if these would get to melting plastic temps before some kind of catastrophic failure happened to the Luxeon...
VidPro said:
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
