cratz2
I picked up two of the 2xAAA Bolt Series lights and one of the 2xAA Bolt series lights. Very impressed considering the price.
The 2xAA is two or three times as bright as the Radiant 2xAA light and it is a bit brighter than the 2xAA Minimag LED but I suspect the Minimag has more throw when focused most tightly as the 2xAA Bolt has a wider hotspot.
The 2xAAA light has an interesting beam... not really a true hotspot/corona/spillbeam; more like a wide flood with a very small brighter spot in the middle. I like it quite a bit but I tend to like smaller lights to lean towards flood rather than throw.
The 2xAAA Bolt is a great size, but quite a bit larger than the 2xAAA Minimag. I might try cutting the rubber part off of one to see if it feels any smaller. Plus, while the rubber coating will probably be great for use in the cold or with gloves, for pulling out of a back pocket on a warm evening, I'd rather it not have the rubber.
I'll have further comments and will post beamshots, but for now, here is a group pic along with the equilavent Radiant series lights:
