Inova T4 Disassemble?
Chinky2
does anyone know how to take apart a T4, i tried twisting the head but it seems to be on pretty tight im at that point where anymore strength and things will start breakin.
The head is secured on with locktite and is very difficult to remove. I took my first one apart but don't recommend it. What is the reason you need to take it apart?
Bill
i want to change the led to something better, its bright but the color is alittle dull.
so it is screwed in?
because I have only disassembled identical looking T1s, T2s and T3s and with them the front part is pressed in,
it is a matter of "freeze-pop"
... which will NOT work here because of the switch assembly, I think. (You can try, but ...)
also freeze-pop usually kills else the led, or the driver circuit, or both.
A simple Emitter swap is not possible with Inovas.
