orionlion82
- Joined
- Dec 21, 2006
- Messages
- 296
kinda got a snag with my $30 nightvision project.
and its all that much more difficult because i cant see what im working with and i cant get my head around the numbers...
ive got about 5v to work with. (might be as high as 5.5)
i have 15 IR led's (dont have to use them all but several might be good)
i can draw up to 100Millyamps, but an unknown device consumes an unknown amount allready. i MIGHT be able to get away with up to 500 millyamps
(read this) but i would like to stay within spec.
i would also like to design my circuit to draw the least current for the most amount of light in the smallest size...
Voltage? glad you asked. 1.2 to 1.7 @ 50 millyamps. per unit.
it allso lists the radiant power at 100 milliamps as 10 to 16 milliwatts.
i have no idea how bright that is.
i dont even know how hard i should push them at what Ma...
im thinking of just hooking 8 in series with no resistor, but thats 400 millyamps right there! right?
(and realistically i probably want to go with 5 or 6 to keep from washing out close up objects)
where do i even start with this?
i dont even know how to approach it.
ive only dealt with the 3V led's at 12V and thise numbers dont work, heh.
tia
EDIT: all the led calckulators ive been using come up with about 100 or even 200 milliamps depending on if the numbers oncy shift slightly? i have to be approaching this the wrong way...
tia
