Is MadMax Plus output current 700ma or 900ma?
wildstar87
The current specs up on the Sandwich Shoppe put this at 700ma, but I've also seen documentation, and mention of this going to 900ma. Just wondering which one is the correct figure?
If I understand correctly this board will draw 1 amp at the source. So if you have 2.4 volts you are looking at 2.4 watts less losses thru the driver, which is roughly 500 ma with a typical LED.
