Hi guys,
I was looking at my HID bulb and I noticed the return wire is slightly bent, about midway it looks too close to the bulb than it should be. Normally there's about 1 mm of space in between, but again halfway down it looks like there's only 0.5 mm. I did drop my light a few times, but I'm not sure if that would generate enough force to bend the wire. Generally I thought return wires were straight across the board, but I could be wrong. I was going to straighten it out with a pair of neddlenose pliers, but thought I should consult here first before I attempt anything drastic.
Thanks,
Dudemar
Thanks,
Dudemar
