Outdoors Fanatic
Does anybody knows where to find them? I need at least 3...
Thanks in advance.:twothumbs
Wow, that was a near miss. I've only had mine a few weeks, haven't even gotten my charging spacers in yet.
Charging spacers? You don't need spacers for a YOHO. That is, unless you want to try to charge something smaller than a 17500. That wouldn't be advised.
Dave
Wrong.AW's IMRs advertise a maximum charge rate of 1.5A.
The Yoho advertises a maximum charge rate of 1.0A.
I'm impatient and cheap. But mostly impatient.
AW IMR18650
Specifications:
Nominal Voltage : 3.7V
Capacity : 1600mAH
Lowest Discharge Voltage : 2.50V
Standard Charge : CC/CV ( max. charging rate 4.5A )
Cycle Life : > 500 cycles
Max. continuous discharge rate : 10C
Right.Wrong.
IMR16340 Specifications :
Capacity : 550mAH
Standard Charge : CC/CV ( max. charging rate 1.5A )
Max. continuous discharge rate : 8C
Operating Discharge Temperature : -10 - 60 Degree Celsius
