Is this a correct setting to check Amperage?
ptolemy
If not, what should I do to measure amperage? Thanx!
Re: Are these the right setting to check Amperage?
You have it right; your flashlight is drawing 1.85 amps from the battery (not at the LED/emitter).
How can I measure how much is emitter drawing on high?
This light is rated for 3amps o high (regulated) and in pas it was buggy and emitter and board wouldnt work so it'd draw less than 2amps, so i want to verify it
If the high mode is accessed by the bezel, turn it; if it's accessed by a soft-press, momentarily remove one of the probes then replace it - this is the same as a soft press.
When measuring on a multi-mode light, it simplifies things if you set the light atop something transparent so you can visually see what mode the light is on. An upside-down glass or tupperware container works nicely.
it is multimode and it draws 1 amp on 2nd and .2 on 3rd. but issue was in past that pill drew 2 amps and regulating board drew another amp, hence it was 3ams resulting in 900 lumens light
if it just draws 1,9 amps from 18650x2then its an issue?
The amp draw from the battery is the total amount of current being used by everything; both the circuitry and LED. So there's definitely not 2 amps going to the LED.
i got this explanation but I cannot figure out what it means
who is right?
3a is the forward current driving the LED pill while the voltage is regulated at ~3.6V. The current you measured should be within the voltage range between 5.4V to 8.4V. Therefore there's nothing wrong with the LED engine.
thanx;)
Ahh, sorry, I assumed you were using the same voltage/battery config; More voltage means less amperage when doing battery current draw measurements, so the other guy is correct.
ok thanx. i am very to this custom stuff, so learning every day:D
Also those leads use thin wires which add resistance inline. I noticed when using heavy 12 gauge leads my amperages would go up considerably. Flashlights that previously measured 1 amp would be up to 1.2 and my P7 DD light used to say 2.8 amps with the thick wire that went up to 3.2 amps
