Have you considered the impossibility of that? He could keep walking east or west, but not north or south. :kiss:
Humour does not always have to make perfect sense .. It made me laugh anyway.
Yeah I know, living in another continent sure is nice.You're lucky you live so far away from me.
Sorry for my comments, but there's just too much speculation on what happened without any proof.
The eyewitness is a non flashaholic, which I think can't accurately describe these things.
I worked out the riddle (ie more speculation). Your friend went to a funeral. He had to travel a long way from home. Before he left, he checked his flashlight, before packing it into his bag. He might even have changed the battery, and tightened the tailcap. Your friend lives at sea level. The funeral was at a higher altitude. The air trapped inside the flashlight expanded as he was no longer at sea level. He turned the flashlight on, and the heat caused further air expansion. The glass shattered and blew out. As the flashlight exploded, the pill moved forward and broke contact with the battery terminal. Your friend dropped the flashlight to the ground, causing more damage. He picked it up and tried unsuccesfully to turn it on. Still anxious and shakey, surprise turned to anger. He threw it out in a fit of rage. Maybe.
Yes you are right, he would recognice them in a non-flashaholic way which is not accurate because he does not know what to look for.
15 PSIA at sea level. Heat the case of the flashlight to 100 degrees C, and you only get 20 PSIA inside the flashlight. Go to 10,000 feet and you only get 10 PSIG.
1/2 inch diameter of the head. 7 pounds of pressure.
Probably less because 10,000 feet and 100 C is probably way too high.
10 PSI of the small amount of air in an A3 or 7 pounds of force is not going to make much of a bang.
This is like a debate on what does a weather balloon look like.Maybe you wouldn't have recognized broken glass, the sound of a gunshot, shrapnel embedded in the skin and the other things he described before you joined this web site, but I think most of the rest of the human race would have no problem doing so.
Gunshot next to his ear and no any damage to his hearing? LOL!
