csshih
perhaps.. then again, the one at the head is a momentary tactile switch.. those don't break often, and don't take much current though them. likelihood is slim.2 x switch = twice the failure rate possibility?
If you have an iTP C7 or C8 it seems like it is the same as the Eluma you are already getting outside of the extra switch.
That's what memory is for. Most of the time I want it on high, as I have my Preon for low light needs. When I do need it on med or low, or more often strobe, I don't think I've ever needed it in less than 5 seconds. (strobe is almost instantaneous when needed, 2 clicks)I would not say they are the same.
It can take at least 5 seconds to get the right power level on the iTP C7/C8.
With the SA1-2 you can get to the common used low-med-high in a hurry.
The R2 version has a more throw than the R5 but the R5 is rated for more lumens. R2 has a tighter beam and the R5 is more flood. Hope that helpsHi to all. I wanna buy one of this Eluma SC1, (1x CR123), what is the best emitter for this light, the XP-G R5 or the XP-E R2? Anyone has tried all the 2 versions? can anyone explain me the differences between the R2 and the R5? (I see that both of versions came with smooth reflector)
Thank you!
