I keep running into a situation where I fire up an Fenix LED flashlight that's been sitting in my car for a while, and it's dead. Most recently an E0 bit the dust.
I purposely use lithium primaries so that it will hold up under any weather conditions and be ready to go when needed. Problem is, the lithium cells are outliving the flashlights!
After verifying the cell and connections are all good, that it's a bad head, I dissembled the light to see what's failing. The board was warped! Components fell off and I observed cracks in the PCB, and I don't think it happened when I pushed out the pill.
Evidently the (+) lead of the battery is constantly pressing on the PCB with a spring force. Over time, temperature, and force, the thin board becomes concave inward due to this constant load.
Although I spoiled a chance to return the light for warranty service, I learned something valuable about LED flashlights. If the battery tube has a spring on the (-) terminal, and the (+) terminal of the battery presses on a PCB, remove the battery when stored for a while, especially in hot conditions.
Hope this helps someone else... :candle:
