ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received my Jet-Pro I WC R2 from Bug Out Gear CPF Special
The thread of the Jet-Pro I WC R2 is at BOG Jet-Pro I WC R2 Thread
Description from Bug Out Gear Website.
Model: JET-I Pro
Lamp Type: CREE 7090 XR-E(R2 WC bin)
Maximum Output: 210 Lumens
Reflector: Aluminum "Smooth - SMO" Reflector
Lens: Sapphire Crystal
Material: T6061 Aircraft Grade Aluminum Alloy
Finish: HA-III Military Spec Hard Anodized
Batter Type: AA Size Battery or Similar Sized Battery
Circuit: 0.7V-4.2V
Circuit Functions:
General Mode:
AA battery: Low (60 lumens, 4 hours)--Primary (120 lumens, 2 hours)--Max (210 lumens, 50min)
Lithium Battery: Low (60 lumens, 3.5 hours)--Primary (150 lumens, 1.5 hour)-- Max (210 lumens, 1 hour)
Advanced Mode:
Alarm signal -> SOS signal
Switch: Push-Button Tail-Cap Switch
Waterproof: IPX-8 Standard 10 Meters
Dimension: Bezel diameter 25mm, Tail diameter 19mm, overall length 100mm
Weight: 50g
Shipping is the usual very fast from BOG.
Fit is excellent.
The Type III Hard Anodize has some flaws. I have a horizontal line by the Jet-Pro printing on the battery tube along with a small dot of the Type III Hard Anodize missing.
AW Protected 14500 fit with ample room with the label on the battery.
Screwing on the rear tail cap only took about 1.5 turns. It was noticeable to me because all my other lights take way more turns to put on the rear clickie.
The beam is off center.
The tint on the beam is a nice white. When cycling through the light levels and finding a level you like it takes about 1 second and you the beam shuts off and turns on. That means the level is locked in when you turn the light on again.
Low seems low enough to me but I guess there are other out there that want a lower low.
Comes with a lanyard, 2 o-rings and rear rubber boot cover.
CREE 7090 XR-E (R2 WC Bin)
Back of the Cree R2 Module.
Reverse Rear Clickie.
Inside view of the rear clickie.
Size comparisons.
Left, Jet-Pro I WC R2. Right, Jet-II Q5 V1, CR123 Battery Tube
Left, Jet-Pro I WC R2. Right, Jet-II Q5 V1, AA Battery Tube
These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected 14500's.
Jet-Pro I WC R2 - 210 lux @ 1 meter (Low)
Jet-Pro I WC R2 - 1060 lux @ 1 meter (Medium)
Jet-Pro I WC R2 - 3260 lux @ 1 meter (High)
Jet-II Q5 V1 - 4070 lux @ 1 meter
Jet-Pro I WC R2 @ 80"
Jet-II Q5 V1 @ 80"
Left, Jet-Pro I WC R2. Right, Jet-II Q5 V1 @ 80"
Left, Jet-Pro I WC R2. Right, Jet-II Q5 V1 @ 80" Stepped down exposure
Jet-Pro I WC R2 @ 32'
Jet-II Q5 V1 @ 32'
Model: JET-I Pro
Circuit: 0.7V-4.2V
Circuit Functions:
General Mode:
Advanced Mode:
Weight: 50g
Fit is excellent.
Size comparisons.
Jet-II Q5 V1 @ 80"
Jet-II Q5 V1 @ 32'
