I was just looking at this,
http://i61.photobucket.com/albums/h75/pike444/bulbs/64623.jpg
For a tube build (based on the Osram 64623 "Torch" Bulb) I am in planning stages on and I noticed that with the voltage range already supplied by my mag85 this bulb puts out about double the lumens under-driven.
Now I like my mag85 and I'm not anxious to ruin the G4 holder for it by experimenting with another bulb size, but here's my question,.
If the bulb lumens underdriven at mag 85 levels of say 11-12 volts is 2x higher with the Osram why don't people use the Osram bulb with lower voltages.
Is it that yellow?
I'm hoping not because I'm hoping that my build with a 30-60 100 switch is going to be somewhat useful, at least on 60 and 100.
If the low end is unusable a regulated driver is looking better.
I'm tempted to buy another bulb holder just to try the Osram bulb on my mag 85 and see how it looks, at twice the lumens I'm not sure I'd care if it was a bit yellow.
I'm wondering how different the size of the bulb itself is. I notice there is a G5.3 holder available, but so far I'm unable to find out if the TORCH bulb is this form, I'm thinking it is a G4 with thicker pins from what I've read, and so the remaining question is will it fit thru the same refelector holes as the MAG85 bulbs or do I need to go bigger.
Is it that yellow?
