sol-leks
- Joined
- Aug 10, 2008
- Messages
- 1,695
Some initial impressions:
-The focusable head is awesome! the beam pattern looks so good on flood and on throw.
-I have not seen anyone mention this before, but the head can come completely off, just like a maglite, and gives you a candle mode(although it doesn't tailstand which is kinda dumb)
-2 things that bother me the tiniest bit. If u shake it the batteries rattle. Also, the tail cap when fully screwed on, leaves a tiny little gap still revealed, you can see this if you look closely at pictures of the light on their website.
-the button is a little tough to press, but almost in a good way, and the threads a bit tight, probably need to lube it.(what kind of lube should i buy?)
-another interesting thing is that if you remove the head there is more rubber around the led which is not visible when the head is on due to the reflector, it also comes with what i think is replacement rubber for this.
-I havent gotten a good chance yet to compare output yet, but it seems a little brighter than my p4 rc-n3
-Overall, I am super happy with this light, even though i haven't even gotten to use it at night yet.
EDIT: I think it might be able to tailstand and i need to just remove the rubber tailcap, although Im not really sure.
I also screwed the tailcap off and on again, and now its not rattling, so I guess that was just me.
