bigchelis
I got home from work to find a IMR 9 D26 (500 Lumen) for my Surefire 6P. I dropped in two 16340 (not AW's) The light barely had any power. I read the post here about tapping it on/off a couple times to trick the battery.
Then it went on. Wow. Talk about power. The cells began to dim at around 11 minutes and I stopped running it at that point. I was hot; amost too hot to handle. The sucker is bright and has good spill.
*Next I will be running it in a 2 18650 AW set-up. 6P bored with 18650 extention.
In my P7 LED I wrap it in aluminum foil to help with the heat.
What can I do to help with the heat from this heat issue??????
