AFAustin
I received my first Baltic a few days ago from Peak---just had to take advantage of the nice Springtime Sale (thanks, Robyn & Curt). I've owned most Peak pocket light models but never a Baltic, so I was ready to try one out. Although I was initially inclined towards a HP or UP, after talking to Curt on the phone, I decided to go for the master blaster and ordered a brass P4 SP with 1xAAA and 2xAAA bodies. Curt posted some specs on the very light he sent me here: http://www.candlepowerforums.com/vb/showthread.php?t=230101. I wanted to post a few comments, though this is in no way intended as a real "review". The quality of reviews on CPF has become so elevated in recent times, thanks to selfbuilt and others, that a guy like me who had problems with 10th grade chemistry should probably have to pay a cover charge just to read them.
With the 5mm Peak lights, I usually shy away from overdriving the LEDs so as not to significantly reduce their lifespan. Even though I end up selling many of the lights I buy, I may end up owning some of the brass Peaks forever, so I usually opt for the HP power levels. Curt assured me, however, that the Baltic P4 could easily handle being driven at SP levels, or more, with no sweat. So, my only remaining concern was getting sufficient runtime, and I decided I could live with the estimates Curt gave me. And, after all, popping in another eneloop is NBD.
When the Baltic package arrived, it didn't disappoint. It's just hard to beat the combination of brass and Peak's terrific build quality. I wasn't sure how I'd feel about the size, because the Baltic looked to be a little big for a 1xAAA light. No question it is much more substantial than my Matties, for example, but I like it. It fills the hand just right, and feels more like a small pocket light than a "keychain" light. The 2xAAA is a different kettle of fish, but it likewise appeals to me---I think the long, slim 2xAAA form factor is sleek and different. It rides very well in the front slit pocket of a pair of cargo shorts (oh yes, it's already that time of year in Texas :sweat, with the end protruding a bit for easy access, but with the slim body not taking up much space or making for a big ("Is that your new flashlight or are you just glad to see me?") lump in the pocket.
As for output, I am tickled to death with the beam. It is bright, white, and floody---with a large, relatively soft spot and a wide smooth spill. I am not the tint fanatic that many of my CPF brothers are, but I nevertheless am very pleased with this Baltic's. I have 5mm Peaks that are definitely blueish, and a Pacific that has a decided pink tone (which I actually like). The Baltic, in comparison, is as close to a neutral white as these old eyes can discern. You know those lights whose beam puts a smile on your face every time you fire them up? This is one of them.
The twisty action was a bit too stiff for my tastes, even after a good cleaning and lubing, as well as a couple a hundred twists to break in the threads. But, I happen to like a quite fast twist action, and end up sanding the o rings on most of my twisty lights (I am forever in debt to Lite_me, who taught this very un-handy CPFer that invaluable trick). So, after a few rounds of the o-ring around my Dremel bit being applied to a sanding sponge, I was happy---fast, smooth one-handed twist action.
I did have one small mishap in getting acquainted with the Baltic. In removing the brass split ring (not sure I liked the feel), and then putting it back on (decided the light looked weird w/o it), I did a good job of mangling it. I always seem to forget how easy it is to put a big gap between the wires of a split ring, and how impossible it is to get them to lie flat again. Apparently, since these are brass rings, they are even more delicate. In any event, Robyn has taken pity on me and is sending reinforcements.
As for output, no light meters, cp measurements, etc., from this liberal arts major, but rest assured that the SP version is bright. On 1xAAA eneloop, it has noticeably more overall output (as per ceilng bounce), than my Pacific Ultra on an Energizer e2 AA cell. On 2xAAA, it blows it away. For a bright, floody light, the 2xAAA Baltic can't quite match my Inova T1 (newer K2 version), but it's in the same league. And again, that big soft hotspot transitioning into a wide bright spill really lights up an area beautifully.
If I have any disappointments with the Baltic SP so far, it would be the runtime---I was hoping for a bit better. I did some informal runtime tests, and here's what I got. With 1xAAA (eneloop), maximum flat output was maintained for 40 minutes. At 50 minutes, output was equivalent to my Matterhorn HP 3 LED. At ~55-60 minutes, it was equivalent to my Matty UP 1 LED, which is about the minimum required to be much use outdoors, IMO. After that, there was a fairly long tail that would be handy in an emergency.
With the 2xAAA configuration, maximum flat output was maintained for 1 hr. 5 min. After that, dimming occurred more rapidly than with the 1xAAA version, reaching the level of my Matty UP 1 LED at 1 hr. 16 min. Dimming continued fairly rapidly thereafter, but there was still some tail.
I also tried the Baltic SP head on a Shasta body (Baltic and Shasta parts are interchangeable). The output from such a tiny light (esp. in the pocket body) is a delight, but the runtime is short. I used a 400 mAh 2/3 AAA NiMH cell, and got 16 minutes maximum flat output. I seem to recall MWClint, Peak modder extraordinaire, saying that he ran a similar configuration, except using a 500 mAh NiMH N cell, and got 45 minutes. But, maybe he meant total runtime rather than max. :thinking:
Curt had warned me that the Baltic SP was not meant for alkaline cells, and that I'd do much better with my eneloops. Last night, though, just for fun, I decided to sacrifice an (almost) unused AAA alkie and see what would happen. As expected, there was a short period of strong output---I wasn't even looking at a watch during this little experiment---but I'd guess 20 minutes. Then, after ramping down quickly, I had kind of a nice surprise---the Baltic settled in at a very useable level of a bit less than my Matty HP 3 LED but significantly more than my Matty UP 1 LED---and just kept going and going. I finally turned it off and went to bed. I fired it back up this morning and the little devil just marched on. Again, I didn't time any of this, but I'm going to guess 3-4 hours of this very nice, poke-around-the-back-yard level of output. And, of course, that beautiful smooth & wide floody beam was still in play, giving it a nice advantage over the Matties.
The only down side to this last little alkie experiment was I am now more curious to try out a Baltic in the HP and/or UP power levels. My fellow Peak fan TonkinWarrior has pointed out that, with the Baltic, even the HP level is plenty of light for most backyard duties, and the additional runtime would be nice. All I can say is, how long till the next sale? (Psst, Robyn....Memorial Day is coming up. :devil
In any event, I guess you can tell I already love my little brass Baltic bundle of joy. If anyone's thinking of taking a plunge in the Baltic Sea, come on in---the water's fine. :wave:
Size comparison: Shasta 1 LED pocket; McKinley 1 LED keychain (w/ keychain removed); Matterhorn 1 LED pocket; Shasta 3 LED keychain; Pacific AA pocket; Baltic 1xAAA keychain
Size comparison: Shasta 1 LED pocket; Matterhorn 1 LED pocket; McKinley 1 LED keychain (w/ keychain removed); Shasta 3 LED keychain; Pacific AA pocket; Baltic 2xAAA keychain
