jylong_away
- Joined
- Mar 14, 2008
- Messages
- 39
I've posted a question about this before on CPF, but now that I've gotten my new AW RCR123s, something else has come to..er...light.
Tried a set of AWs fully charged 3.7v protected RCR123s (the new black ones that fit nicely into SF E-series tubes) with the 2008 dual output KX2 LED head from surefire.
The first thing I noticed was that the 'low-level' part of the dual output mode was significantly brighter than with fresh primary cells. It's still 'lower' than the high-level, it's much harder to tell the difference. The high level seems roughly the same to the eye. Have no equipment to measure anything specific.
Anyone have the same experience with the new KX2's? Any idea if this will overdrive the circuit to the point of burnout?
ttran97, you mentioned that you've used two 3.7v cells with your KX2 and it's been OK so far. Have u noticed this issue with the brightness?
I've still got use for the RCR's with 7.2v bulbs and the opticsHQ impact bezel (thanks again Kobi, btw!), but wonder if I should use it at all with the KX2.
I guess the other option is to get a single-cell tube to run the KX2 on. Anyone know of a good tube +/- clicky that I can get on it's own, without having to buy a whole E1B or E1e/E1L?
Thanks!
Thanks!
