bbb18c1
I received my q5 drop in today along with the aspherical lens. After intalling it, I noticed that even with the head screwed down all the way, I couldn't quite get the image of the cree die to be focused properly. The lens needed to be closer to the led, but the head could not go down any further.
I also didn't like the way the aspherical lens was protruding from the head and exposed.
So I decided to to replicate the aspherical light that I paid for from RcatR, but never recieved. http://www.candlepowerforums.com/vb/showthread.php?t=161983&highlight=aspheric
The basic idea was to recess the lens into the head to protect the lens. The first thing I did was I had to grind off the lip on the aspherical lens so that it would be able to sit lower in the head. I then cut the stck mag reflector to fill the gap between the lens and the stock bezel. After doing that, the lens was now too close to the led. The head needed to be completely screwed off to focus the die.
To solve that problem, I took the mag switch out and cut the tower portion off. I then soldered the dropin to the correct terminals on the switch. That did the trick. The die focuses almost halfway down the threads on the head! Now I have the ability to focus it and the lens is protected.
Here are some pictures I took:
wall beamshots (no outdoor shots yet , as it is still bright out)
underexposed:
thanks for looking!
underexposed:
thanks for looking!
